ok, so my supra was startinf b4. i had to crank it a couple of times but she turned over, but now it dosent, i checked,
1. she has fuel
2.she has spark
3.starter turns
the problem is when i try to start her she trys to turn over because i hear the back fire but then she jerks and stops violently...so i yanked out the plugs taht i just put in and they were black (new Plugs) so i pulled them out and cleaned them but then i noticed that oils was in the spark chanber so i started it to have the piston push out the oil, so it was a little cleaner than b4, how the oil got there idk, i guess when i put it in the jerking motion just scatered the oul around but then i noticed that the spark plugs had oil on them by the threads 4 were oily and 2 were dry 1234 and 6 were oil and 5 was, so the ni cleaned them and then i put then back in so after that i reconnected everything and put the coil wires to 163425. i think that my motor might be shot. if the oil is coming from the pistons right then i am going to take it and put it on fire..i am frustrated and out of ideas...help
i dont have a code reader so i cant pull them....
1. she has fuel
2.she has spark
3.starter turns
