Been a long time since I posted here. I traded a mustang for the red and black supra that used to belong to my dad. The car has a jdm 7m and since has had problems it has a new cps, new fuel pump, and a nnew timing belt cause the belt slipped a tooth popping the clutch. It is throwing code 11 which is low voltage to the ecu, and its idling rough unless I pull off the intercooler piping from the 3000 pipe it idles fine so I'm thinking a vacuum leak. The cam gears look really close I'm wondering if the timing is dead on after the timing belt change. And it has a weird electrical gremlin since the motor swap, if the car is off the headlights work as they should but if you start the car the headlights automatically come on and pop up with the headlight switch off and go off if you turn the switch to on but the lights stay up anyway I know some of you guys like a challenge and I like to learn so I got another supra to tinker with
