I am having a problem hooking up my hks twin turbo kit for my 1jz. I got the nuts and bolts figured out, that was the easy part. The problem I'm having is with the wastegate. the stock turbos have a single port actuated wastegate with an outlet on the turbo to hook up the hose. My hks kit has a dual port actuator and no outlet to hook up any hose at all. I don't know where to get the pressure from to hook into the lower port and I have no idea what to do with the top port on the actuator. I hope the pics help. Thanks
