Help designing a "simple" PWM controller
Piratetip
Far From Maddening Crowds
1,179
69
MKE, WI
Calling electronic gurus on the board that can help me design a circuit or modify an existing controller for PWM solenoid control.
Long and Short:
Manually control a 12v Solenoid in the transmission used to regulate pressure.
PWM from 0-100%
Problem:
Vehicle is too sluggish to fully apply/never fully applies
I have measured all aspects of the circuit that I would like to mimic.
2 wire solenoid, + comes from TCU, - grounded internally inside transmission
Driven by 12V PWM signal at a constant 50Hz
Solenoid 12.6 ohms
Typical operation:
V, A & PWM on time %
P - 0V 0A 0%
R - 3.6V 0.25A 42%
N - 0V 0A 0%
D - 3.6V 0.25A 42%
3 - 3.6V 0.25A 42%
2 - 3.6V 0.25A 42%
1 - 5.3V 0.38A 55%
Full lock up would draw 0.95A @ 100%
I do not have an oscilloscope so I would expect the voltages to actually be 12V, since my multimeter is just averaging the pulses.
The plan is to wire a switch to toggle between normal operation and manual control. Manual control will only be used under certain circumstances for short periods to achieve full or close to full lock up. A dummy load would be used during manual switch over to convince the TCU it is still in control of the Solenoid.
Another problem is that it would have to use a high side driver since there is no access to the ground wire on the solenoid.
On another board I found someone that was tackling the same issue but never finished.
Here is a circuit that was proposed.
As he explained it the fan should be the solenoid and transistor should be MOSFET (IRF630B). I believe he was designing it for a 17 ohm solenoid, so that could be an issue as mine is 12.6.
I am not an electrical engineer so I am a little lost in the construction of this circuit.
Anyone know of any off the shelf units that could work or be modified to work?
http://store.qkits.com/moreinfo.cfm/MX033
I saw this one but the Hz is off and requires both the solenoid + and -, which I don't have access too.
Any help would be appreciated.
:1zhelp:
Piratetip
1,179
69
MKE, WI
Ended up building my own from scratch.
Works perfectly, exactly mimics the TCM control of the solenoid.
Used an Arduino and high side control circuit I built.
Everything is controlled using 1 knob, very simple.
The back end is not so simple but that's the beauty of it.
Kai
That Limey Bastard
Piratetip
1,179
69
MKE, WI
:icon_bigg Possibly
It looks like you have most of it sorted out.
What are you trying to figure out for the PWM control?
I used a Timer function for the ATmega328P controller in the Ruggeduino I used.
This allowed me to set a fixed 50Hz (20,000μs) frequency and I used a potentiometer to set my desired duty cycle %.
But I could set the timer for anything from 1 microsecond to 1,000,000 microseconds.
I built a high side driver circuit to handle power delivery to the solenoid.
Although that Siemens chip you found might be a better solution for how many you are controlling.
Piratetip
1,179
69
MKE, WI
Wow has it been that long since my last post here.
Time really has flown by.
Going to have to start a new thread soon.
Moving back home to the midwest soon, new prospects.
Hoping to pull the Supra out of its 3+ yr storage and start down the list of needed repairs/upgrades.
Starting to miss that car....
Piratetip
1,179
69
MKE, WI
Logged into MKIII tech today since....make a guess.
Even remembered my password on the first time, amazing!
Hall of shame :D
Starting to get impatient, wanting to work on the old 87' MKIII now!
