Help 1992 7mgte is making noise
St!LL b0oStEd
94
san antonio
:1zhelp:Well it all started when coming home from work , I started to hear a slight rattle / ticking noise from top end after 3000rpms not at low idle and no noise when idle ,sounds like top end back of motor any suggestions
suprarx7nut
YotaMD.com author
Nov 10, 2006
3,811
Arizona
www.supramania.com
If that's in the top end I would guess it's excessive valve lash. Hard to tell from the video, but I'm thinking its more likely rod knock. Valve tick in my experience sounds a lot higher pitched than your video seems.
Have you checked valve clearances? Valve lash is easy to fix. Rod knock essentially means a full engine rebuild.
akito
Keep Laughing.You're Next
Jul 31, 2006
1,568
Springfield/Va
That doesn't sound like valves tick, it does sound's like rodknock but can't confirm that without further diagnostics
