Heater core crack opinion
Status
Not open for further replies.
swaq
posts++;
May 24, 2005
1,351
Oregon -> Arizona
www.SwaqValley.com
I am in the process of installing a new heater core (see this thread). I test flowed the new heater core with some water and it didn't leak. However, after putting it into the box I noticed a small crack (see attached pictures) where one of the pipes is connected (welded?) to the core. I don't know if this was there before I installed it, or if it occurred during installation. I'm worried that under pressure this joint will leak. Should I try and return this heater core for a replacement?
rayall01
901
Westfield, ma
swaq;1344274 said:
I don't have soldering tools, though I could probably find someone who does... I think I'd feel better about replacing it than trying to resolder it though.
Cmon, just get a propane torch, and a roll of solder. It'll take about five minutes to do. Get some balls, man!:biglaugh:
rayall01;1345548 said:
It can't be much different than sweating pipes, IJ. Lets get a grip here.
I think you should let go of your grip...
Enough's enough you have NFI what his skill level is and a heater core is so easily fucked if you apply heat for too long or in the wrong place.
I know you're only trying to help but you're fast becomming a total knob knock it off.
rayall01
901
Westfield, ma
True, I don't know his skill level, but if he's putting the core in himself, he's got to have some abilities. That said, if he can send it to me, I will fix it and put it in my car. At least then we'll see if I know what I can do.
swaq
posts++;
May 24, 2005
1,351
Oregon -> Arizona
www.SwaqValley.com
I've never soldered or welded anything in my life. I know someone who could do it for me, but I'd rather not run the risk of the resoldered joint being weaker. Also, the heater core is being replaced free of charge.
Curt said he is sending me a return label with the new core, so I assume that means I'm supposed to mail back the cracked one.
Rayall01, is your heater core bad? As far as I can tell my old one doesn't leak (though I haven't tried flowing some water through it), it was leaking from the bent up connecting pipe in engine bay. I can send my old one for cost of shipping if you want, since you don't seem to mind if you have to tear apart your dash again.
rayall01
901
Westfield, ma
Nah it's not bad, just old. I figured if you didn't have to send it back, I could get a chance to show off, that's all.
jetjock
creepy-ass cracka
Jul 11, 2005
9,439
Cores are usually vacuum brazed. That said hand brazing takes more skill than soldering. And assuming it is soldered the solder typically used for sweating tubing won't do because coolant will eat it. Especially if it's Toyota OEM coolant. Based on all that he'd be smart to simply replace it...
rayall01
901
Westfield, ma
Since he's already said he's got a replacement on the way, it seems a little superfluous to keep saying he should get a new one.
When did this become about what you can do?
Turning a wrench in no way equates to being able to repair a heater core so your observation about his ability is flawed right off.
This is NOT going to turn into an argument or even a debate on what can and can't be repaired.
Status
