jetjock said:
Batteries huh? As a friend of mine likes to say: "Crude, but effective".
Powering the WB heater from the stock circuit may work as long as the stock heater is disconnected and the WB heater doesn't draw more than the stock one did. In that case the ECU will be happy and you'll remain code free.
I don't see why the lighter circuit didn't work but I don't know the current required for the WB heater. Seems like it'd be less than the lighter but without checking I dunno.
I'm confused about the ECU being in open loop. You're running the emulated WB signal to it right? If not you should've already had one of the other O2 codes set.
Yes--exceedingly crude, indeed, but it has been effective enough to allow me to get by without worrying about the wideband wiring for quite some time now. The batteries last at least a dozen hours of drive time, and I have an automotive battery charger that can recharge them pretty conveniently.
Assuming that newer O2 sensor heaters are more efficient...I think the power will be OK. Mostly, for using that as the solution, I'm worried about having such a strange setup...with wires coming from the harness, across the turbo area, and through the firewall, all the way to the wideband unit in the cab. But coming from hauling batteries, I can't say that isn't an improvement, haha.
The cig lighter, if in perfect condition, should power the WB just fine. However, something is wrong with it, and it has a low maximum output current. For instance, it will charge my cell phone--but not start my power inverter, even when it has no load. It has a 2 ohm path to ground, which is a bit high, but I verified that the WB will warm up properly if it gets a + supply from somewhere other than the cig lighter, and uses the cig lighter's - terminal for the return. If I indeed direct-wire the WB, I don't really have much use for the cig lighter, other than my cell phone--though perhaps the inverter would be nice on occasion. I've yet to figure out what the problem could be on the + side of the cig lighter, and threads I have created about it in the past have been very unpopular.
I run the ECU in open loop, because my MAFT-Pro is operating in "Partial Throttle AFR tracking" mode. In this mode, the Pro tunes the AFM signal using a feedback loop with the wideband to reach a frequency where the ECU's open-loop calculation is perfect. It's pretty awesome, and a heck of a lot faster and more accurate than the stock narrowband feedback! Also, it is more flexible, in that the MAFT-Pro can regulate different AFRs for idle, general operation, as well as leaning out during cruise if desired. WOT AFR tracking is always available, because the ECU runs in open loop there too.
Since you're the TCCS expert around here, I'm sure you didn't need that much of a description--but maybe someone else will read it and discover the wonder of PT AFR tracking
