Heat dont work, accordian intake
89Turbo7M
BLUEBULLET
Jan 12, 2008
120
area 51
need help the heat dont work in my car but blows cold air also i have a cooleeze accordian intake they dont make anymore where could i get raplacement couplers or another good replacement?
shaeff
Kurt is FTMFW x2!!!!
9
Around
Replacement couplers: www.siliconeintakes.com
Heat issue: check the heater valve, located on the firewall on the passenger side (LHD cars). There is a plunger on a steel rod. Push it all the way up and zip tie it in place. See if you have heat. If so, verify the vacuum source is good. If it is, the heater valve needs to be replaced, or left tied up. (I'd rather replace it)
