Head Removal from Block
Nate
GSWAG
Dec 26, 2006
31
Queens
I removed the valve covers,the bolts under the cams are they head bolts right?
Or does the gasket in between have the bolts under it?
CyFi6
Aliens.
Oct 11, 2007
2,972
Phoenix
www.google.com
Yes, the headbolts are under the cams, and are 10mm allen. Make sure you remove them in the REMOVAL order and make sure you do it in a few passes, not all at once!
NO the magic number is five. ON your sixth one, it's like making mud pies........just as easy as can be.
sneakypete
Regular Member
Jul 18, 2007
1,129
Central NJ
92nsx;1101037 said:
Remove - only one person needed.
Install - need two people, trust me ;)
if the block is out of the car, its do-able to install the head with one man. but its still a good idea to have an extra person
