before you guys stop reading i know this has been sorta covered before and its in the wrong section but i tried posting in the head gasket thickness sticky and no response
my head has already been shaved .020 and will probably need another .015 to get smooth thats almost 1mm that i have to make up really can't pull the block right now nor do i want to if i run a composite gasket with that much material removed will it even work or will i run into clearance issues, also what about my timing and compression ratio?? i know it sounds crazy but is there a way to bond two composite gaskets together???
im not looking for smart ass comments just need help and advice so i can possibly get the car running for a short period of time so i can get it somewhere to pull the block to do it right
