I have a wee problem with the turbo I have, it is the HE351ve with the variable vain gizmo. I have a 935 stainless header for the 1jz with a divided T4 flange. The 351 uses a nonstandard flange that fits between a T3 and the T4. I have found a mild steel flange for the 351. The conundrum is do I hack the T4 flange off and weld this to the stainless pipes, or I could get a T4 flange and weld that to the turbine housing. Or get a t4 flange and the 351 flange and make an adapter. the last is a problem if the adapter is too tall, as clearance is an issue with this turbo. I suppose I could also build my own header but that is uncharted territory for me.
Any wisdom for me?
Any wisdom for me?
