I didn't know where to put this so im put it in general. Mods, if im in the wrong place please move it.
First let me ask a couple of questions about our supra and our harness, including body and engine harnesses. How many engine harness are out there?Does 89 has it own harness or it would be the same as 90 91 and 92 Because im really confused right now. First i aquired a 7mgte with a 5spd harness, it was a 89 with gray plugs, to make things easy since im swapping over for an auto trans i traded the harness with a member on here for a 89+ engine auto turbo harness with gray plugs. So i swapped the harness and ECU. Today, after i had placed the GTE motor in, went over to try ang plug up the ECU, ecu is fine, but BODY harness does not match at all.
There are the same amount of plugs, 6 grays and 1 white. So the white one on the harness is bigger has more wires than the one from the body. Second one is the square plugs in there, on the engine harness it has 13 wire and on the bogy harness it has 16 with one purple dud. Another one was a gray one that has 9 wires sizes of the plugs are different. So idk what to do, we are trying to figgure out if we can cut and match wires to use the same one on the NA engine harness.
So im kind of stumpped. I want to know if the plugs are different because my car doesnt have ABS, Air bag, tems, sunroof, because all i can think of is those plugs are for the rest of the accessories on the car. And 89 and 89+ have different harness? What is the best way for me to do with the one i have.
Thanks in advance!
Thanks in advance!
