So I finally got my freshly rebuilt (stock) GE running again, and it is pretty hard to get it to start up once it's warm. I've only done it a few times now-but when I go to start it up when its hot-it gives me a lot of trouble.
timing has been done. Car runs great once running.
initially-it wouldn't catch when hot-and would just continually turn over and over and not catch. Then, when it did catch, it would rev-up and then drop down to around 300-400 rpm and slowly make its way up to 700 in increments.
but more recently-it just refuses to catch-and I have to turn it over several times in increments of about 5 seconds. Pumping the throttle seems to help it catch sometimes.
So I checked for codes and got a code 14. Checked the ignition coil and found the primary coil has a resistance of around .4 ohms (spec is .24-.3). Secondary coil was within spec.
so my question is this:
has the code 14 got anything to do with the hard start? I'm not too well versed on the ignition circuit-but I have my doubts that the primary coils resistance is causing this hard start problem.
any input you guys have is welcomed and appreciated
