I'm wondering what's going on with my transmission here. It some times doesn't likes to downshift into 2nd no matter what speed/rpm I am at. An example being, I pull into my drive way and coast along from maybe 15mph and try to go into 2nd and it wont. I eventually almost come to a dead stop and still it won't go into 2nd. Reving doesn't seem to help it shift, however I noticed if I shift to N, let the clutch out then clutch back in and go to 2nd it seems to work better. When attempting to go into 2nd it makes a sorta whirr noise very faintly and I never try to force or apply pressure to it.
No other gears have a hard time that I've noticed shifting up to 2nd hasn't been an issue. The fluid is fresh MT-90(proper level), MC is bleed(edit:slave also) and from what I can tell the clutch pedal is adjust correctly.
Does that narrow it down to the transmission just needing a rebuild or maybe a bad synchro? Or, could the MC or clutch pedal need some attention? Or maybe I'm just a bad driver lol I only recently swapped to the 5 speed and it's been a learning process. I learned to drive on a stick and ride a motorcycle so I'm certain not new to the idea of changing gears, just re-learning I guess to use my foot for the clutch....
It's an r154 swapped into my na.
