Hard start/Funny idle - 7mgte ISC problem?
Is this an ISC problem? Maybe it isn't closing fully? or??
Any other ideas? Where do I start looking?
Out of nowhere, my 7mgte began to start funny. I would have to work the throttle to get it to start and then continue to work the pedal to keep it running at 2k rpm or so. It would be running rough with the vacuum gauge needle fluttering hard at 5, when normal idle is 17-18 without flutter. It would run this way for about 1-2 minutes and then suddenly it would smooth out and give normal vacuum reading. Cold starts or warm, this went on for about 10 days and then it seemed to go away. What remains though, is a starting idle that often has a bit of a lope or roughness to it for a short period. The MPG has dropped from 18+ mpg to barely 16 mpg, My codes are unchanged (32,42,51,52) that have been in place forever. Light load shows a reduced vac reading dropping from 10 to 5ish. The cold idle vac reading seems down by 1-2 points.
