Hi guys,
i've got a haltech e6x running on a 7mgte, its been to the tuners once, they managed to do a base map and made some good power with a miss, (284rwhp @ 8psi)
turns out the miss was the Gapping on the CPS it was 0.4mm or 16thou
i regapped it to 0.2mm or 8thou (lower recommended in the TSRM still within spec)
the car ran awesome! was a little hard to start and didnt want to idle until warm... but did not miss a beat whilst driving!
as were moving into winter in Australia its getting colder (round 10deg C once the sun goes down)
it wont actually start when cold, i re-gapped the CPS to 0.3mm and it starts but has the same miss issue. i've tried a few different cp's with no luck....
I'm not the biggest fan of electromagnetic reluctors... its analogue after all
I've done a search on this and found not much
has anyone had luck converting it to hall effect and how did they do so? i think Duane did it?
I'd love to know how/see pictures. are there any other cam sensors that may bolt in? if needed ill fabricate a slotted wheel but id like to know if there is a better way.
