In case you don't know, the turbo consists of 4 connections
1. You have a feed of clean fresh air from the air filter that goes to the inlet side
2. There is an outlet to the intercooler which will send (compressed) air towards the engine
3. There is a feed from the exhaust manifold which makes the turbine spin
4. There is an outlet to the exhaust pipe for the waste gas
Basically, the exhaust gas leaves the manifold and hits the turbo causing a shaft to spin. The gas then exits the turbo into the exhaust pipe via the turbo elbow. When you hit full boost and the wategate opens, some of the gases bypass the turbine wheel and go straight to the exhaust. At the other end of the turbo, the spinning shaft drives a compressor wheel which is sucking in clean air and squishing it down before forcing it out to the intercooler.
Step 1 - Follow the guide to remove the 3000 pipe
Step 2 - Undo the large clip attaching the accordion hose to the turbo inlet
Step 3 - Undo the two clips shown for the ISC (idle speed control) valve (top one) and PCV system
