Got a new car used a fresh long block 1jz with all my jza70 setup that was running in my previous supra
Went single this time so that's new but everything else was left stock
Started the car runs perfectly so I let it warm up first than give it a rev a whole whopping 1500 Rpms is all it goes to before falling flat on it's face with sputtering checked air fuel ratio it's lean under idle and when u accel it gets worse once the throttle bodies closed it richens up and the Rpms go up
The car is a 91 auto turbo the engine setup is from a manual jza70 that was running great for about two years in my old car
At this point I have checked all of these things
-the engine harness for resistance and volts
- checked and replaced cam angle sensors crank angle sensor map tps idle speed ignitor ecu air temp water temp
-fuel filter, fuel pump, fuel pressure regulater, checked for kinks didn't see anything
-checked the volts on all the grounds and it's showing proper volts
Haven't checked the cams contacts with cam angle sensors and relucter wheel for crank as well as if the izuzu timing belt is the right size that I'm using
Could be a clogged fuel line car was not running when I got it and had been sitting with the fuel lines disconnected from the the rail
