Last night I got my very first supra. 87 white, non turbo, non tt, 5 speed. Has a cracked headgasket but drove the car home 80miles no problem. Everything works and shes in great shape especially for $500.
That being said I am new to supras but not to cars. I've been into domestics up until now except the 95 toy pickup I owned a few years ago.
As a disclaimer please dont say just turbo it blah blah blah. I've done ALOT of research before I even bought the thing and am fully aware of what its capable of reaching power wise NA.
The plans for the motor:
Find another 7mge in good shape.
Break it down, clean it up, and rebuild
New bearings, seals, and punch it over .060
Modification to bottom end will be a high volume oil pump, crank scraper, and pistons to achieve 10:1
Things I've been trying to find out: Who makes some decent pistons that arent $700? I know you get what you pay for and such but I come from the world of SBC's where a full rebuild kit is $700 for decent parts. I'm trying to achieve 10:1 as I said. I'd like to run 87 or 89 octane in it which I think wont be a problem with 12-14* base timing.
As far as the head goes I'll be gasket matching it and port and polishing at home. Brian Crower stage 2 daily driver cams, BBC springs and freshen the valves. Same goes for the intake plenums as far as port, polish, and gasket match.
It'll get a pacesetter 3-2-1 header, 2-1/2in exhaust and retain a resonator, cat, and muffler to keep her legal.
Other general mods I plan:
Fidanza light weight flywheel
Clutch which I'm open for recommendations on
Aluminum 1 pc driveshaft
eibach 1.5in lowering springs
solid sway bars
So basically its your typical 7mge stubborness of not wanting to swap to turbo![Big Grin :D :D](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
To recap questions here:
What pistons are a fair price but still decent quality for 10:1?
Are the stock cam gears adjustable? I thought I read somewhere they could be adjusted 0-4* but I closed the window and couldnt find it again...
I'm not used to having an aluminum headed motor so with 10:1 and regular base timing what octane should I be running?
Btw this car will be lightened and run on road courses and daily driven occasionally.
solid sway bars
