Sup guys. I have a gt35r that I bought from a forum member here and I am getting ready to put it on. Parts that I have on hand to go with it are as follows,
gt35r
exhaust manifold
downpipe
oil feed line
oil drain adaptor -(bolts onto sump)
exhaust manifold studs/nuts for the lower exhaust side to clean shock tower
intake pipe with filter
tial 44 mm wastegate 15 lb spring
APEX AVCR + SAFC II
550cc mkiv injectors with resistor
Stuff I need
oil drain line
oil restrictor (may have come with feedline)
Wideband 02
BOV
Stuff my car has
MKIV TT fuel pump. The guy I bought the car from said that he installed this, I have yet to confrim.
Stock internal 1jz.
exhaust.
Greddy FMIC for 1jz
rebuilt R154 by MC and Action 6 puck ceramic/metallic disk with an ACT EXTREME 3000lb pressure plate from DM.
1. Should I purchase an adjustable fuel pressure regulator to put on now or can this wait?
2. Do I need to purchase any other supporting mods?
3. Is their an order you suggest installing everything or just throw it all in there?
gt35r
exhaust manifold
downpipe
oil feed line
APEX AVCR + SAFC II
Stuff I need
oil drain line
Wideband 02
BOV
Stuff my car has
Stock internal 1jz.
exhaust.
Greddy FMIC for 1jz
