I've seen several threads for the R154 and the proper gear oil, and from what I gather it'd be best to use Redline MT90 gear oil. However, haven't come across any posts asking if this is also the proper oil to use in the W58 gearbox.
In the past six months, I've noticed my trans is getting a little harder to get into second and third and would like to change the gear oil, so I figured while i was putting GC in the engine, I might as well take care of the trans too.
I read your corrected post about Valvoline's gear oil changing viscosities and makeups, and didnt know if there were any recent updates.
I also can't find the Redline oil locally, what would be the best substitution readily available from Advance, AutoZone or NAPA? (I realize you don't keep a running stock of gear oils in the Salem, VA parts stores but what would I likely find that would do the trick?)
Thanks!
Thanks!
