GE and GTE oil pump difference?
ricerkid
57
St. Louis
I am rebuilding my engine this winter and was wondering what the difference is between the GTE and GE oil pumps.. i am guessing that the GTE oil pump is just a higher oil pressure since it goes through an oil cooler? I have a GE motor and am wondering if a GTE oil pump will be fine to use. Thanks
Clip
The Magnificent Seven
Oct 16, 2005
2,738
9
Virginia
i'm using one of Driftmotion's worked over oil pumps on my GE with no problems whatsoever. also got the larger hose.
gofastgeorge
944
Texas
CyFi6;1459847 said:
Supposedly the GTE pump is higher volume
Fact, it is a larger displacement pump.
The gears are longer by about (going from memory here) 5mm.
Use the search button, I know pictures are posted somewhere here.
