indy_mk3;923870 said:
ya well i just put non adjustable struts on it and well my old cluster lights dont light up as well but still the whoel cluster is for a 89 turbo and i have a 87 turbo and my boost gauage wont work either because i disconected the stock boost gauge and replaced it with a sport comp but on the new clsuter the fuel gauge, the temp gauge, and the tach doesnt work, the oil pressure never has wokred because i swapped a JDM block into it and forgot to change the sending unit clip becuase i have an american car, and my speedo doesnt work because my cable is broken but i still aint to sure what im gonna do....can i possibly just chaneg the gauges themselves into my 87 cluster's board??
Yep. As Dan pointed out, all you need to do is swap the driver board from your old cluster, with the driver board in the new cluster if indeed your problem is a circuitry issue. On the other hand, u said that your fuel, tach, and oil pressure guages aren't working now... my next question would be why you are even attempting to swap guages at all... all ur old ones with the exception of ur speedo work right?
Anywho, switch out ur driver board and see if they work then...
Oh and to reiterate a previous post and simultaneously correct another, the Turbo tach will work in place of a NA, its the vice versa that will not.
