So I finally got everything back together on my car after doing an engine swap (rodknocked 7mgte to rebuild 7mgte).
My driver side headlight is not working on low beams now, but it will on high beam. Fuse is good, wires near the connect seem to be fine, down the line, I'm not too sure. Possibly something with the plug? Or maybe somewhere farther down the wiring?
Now onto my gauge cluster...
I've had problems with it even before I did the swap.
Now, nothing is working,
I thought it was the gauge cluster I had in there, because it had some aftermarket afterglow shit in it, but I swapped a different stocker in tonight and didn't change anything.
What's going on is there is no lights when I turn on my headlights, dimmer switch is plugged in and have fiddled around with it, nothing. My door open, battery and abs lights all come on when they're supposed to. However, none of my other gauges are working, my oil pressure shouldn't be, and I don't think my water temp should either, but my boost, fuel and rpms should be. The RPMS on the new gauge however stay at 0 when it's on and idling pretty low (I think the timing is off right now, not responding too well when the throttle is pushed) but when I press in the throttle, it jitters up a little bit around 1k.
Anyone have any ideas?
All the plugs are connected to the back of the cluster, but is there a main plug that I might have forgot to plug back in when I had my dash and everything out? My ECU has all the plugs filled, and I don't see any other loose connectors in the glove box area...
