Hello.
Haltech E8 here installed on 7M-GTE (injectors are paired). Last summer I was running 550cc injectors in multipoint mode and everything were ok.
Now I've installed 720cc and got some problems.
I can't tune AFR in ANY injection mode. In batch/multipoint I can't tune any load above idle and free-revving. Enigne misfires badly and leans. Increasing injection time doesn't help.
Semi-sequential mode is better. Engine revs till 5500RPMs and can be tuned even under load but in 5400-5800 range still leans badly (and misfires). Besides that it runs very rich @idle (can't tune leaner than 12.xx)
I've converted fuel rail to dual-feed. Installed SS fuel lines (-8AN). Replaced walbro with bosch bosch 044. Nothing helps! Just moved "problem RPMs" a little.
Guys, please describe your setup running paired injectors... 720cc and larger.
I suspect that problem is in Haltech semi-sequential mode. It fires each channel twice per cycle (every crank rotation). Stock ECU (and p'n'p AEM too) AFAIK fires each channel once per cycle (every two crank revs). Am I right?
I'm very angry and disappointed. 550cc are too small for me. I already wasted lots of money (new pump, new lines, 720cc)... I don't know, if 680cc will work or it will be another 600$ trashed... What shall I do?
PS: injectors are good. I've checked them.
PS2: Bosch 044 in-tank, 10mm supply line (-8AN), new stock fuel filter under hood, T-fitting, dual-feed rail with drilled and taped return in the middle. Aeromotive AFPR then. Tried completely stock fuel supply with walbro in-tank - just the same (even slightly worse).
