Im currently wiring a 1JZ into a 1987 mitsubishi starion. My question is which wire from the ECU can i use to power my fuel pump relay? I know on the pin out there are two wires that run to the factory fuel pump relay, but i dont have that. pin D1 and FPC. From what ive read already, you can not use FPC directly because at idle it doesnt supply enough volts to kick the relay on. So anyone doing an odd swap, what wire do you use from the ECU to send signal to kick on the Fuel Pump relay?
This is what im looking at. this matches my ecu
