I was able to start and run the car two days ago. I ran out of gas. Now I cannot get any fuel pressure like the ump isn't working. I have tried jumping the diagnostic block that did nothing. I tried running power straight from the battery to the pump nothing. I figure that the pump is garbage and needs to be replaced. The odd thing is every so often it will spurt gas from the line. Very very hit or miss. Could there be a ground I am missing somewhere. Could it be the relay in the pass. Kick panel? This issue is driving me batty. I need to get her up and running so I can take it to the garage and repair the brake line and power steering low pressure hose. Seeing as my driveway is covered now with all sorts of various fluids and don't really wanna crawl under it.
And to replace the fuel pump drop the tank replace pump and reinstall tank. Anybody out there cut an access hole in the hatch to make this much easier to do. And if an additional hole is cut for the fuel pump will that significantly affect the rear unibody?
