Fuel cut ???
zoonwen
1JZ Supra
Apr 27, 2005
199
Denton, TX
I hit fuel cut when i 1/2 throttle, im guessin my w/g is crepping. I have a front mount and straight exhaust. Whats the best solution to solve the fuel cut issue ????? :wtf:
GrimJack
Administrator
Dec 31, 1969
12,377
Richmond, BC, Canada
idriders.com
Nope. I had a leak, I could still boost to 14psi. The leak had to get pretty bad before I had problems boosting. As in, I had a crack almost all the way around the coupler from the 3000 pipe to the throttle body.
zoonwen
1JZ Supra
Apr 27, 2005
199
Denton, TX
what is the best way to keep the wastgates from creeping ???? I heard that the wastegate port is to small on the 1J and it dosnt allow enough flow to keep the turbos from spoolin up.
