I'm having a few issues with my car at the moment and have been trying to figure them out for the past few weeks. I've gotten it to the point where it runs well and is drivable, but there are still some very irritating problems I'm having trouble with and I was hoping if I posted them up here maybe someone would chime in and point out my stupid mistake(s) =)
Mods: K&N intake, 3" DDP from ZW motorsports, 3" high flow cat, 3" RS-R GTII catback exhaust, Walbro fuel pump with 12V mod, J-tube delete, driftmotion spearco replica IC and hardpipes with HKS replica BOV. Everything else is stock, including the CT-26.
The most annoying one is the fact that no matter what, my car keeps boosting to ~12 psi and reaching fuel cut. Is it possible with my mods the airflow is just high enough that boost cut is triggered/the wastegate doesn't open?
It builds boost pretty quickly, as my aftermarket gauge shows, but it also feels like it has less power than before. I used to have a 4.30 diff compared to my 3.73 now though, so I think that's why it feels slower.
I've checked for boost leaks, everything is 100% tight.
I've tried using just stock boost by putting a hose from the compressor outlet to the wastegate, it hits fuel cut.
I've tried using a ball and spring MBC set at the lowest setting and various other points, it hits fuel cut.
I've tried using a HKS EVC II EBC set at the lowest setting and varius other points, it hits fuel cut.
I'm about to go out and pressurize the wastegate by hand and see if it opens. The weird thing is my car used to run perfectly with the exact same setup in my old chassis. Boosted up to 10 psi using the same MBC and held there, never overboosted and had only tiny bits of boost creep. I did put on a brand new accordian hose but that shouldn't be an issue... every hose is tight on there. The car runs very well and I can't find anything wrong, which is why this is so confusing!
I've heard of people having trouble with the stock CT-26 wastegate hitting DDPs, can someone fill me in on that? My DDP is the same one I used before and it never had problems =\ I did change the gasket but that shouldn't do anything either.
Another little issue is that my tach doens't work. It just jumps around near the range where my RPMs are. I think it might be a bad ground point somewhere, I've tapped into the IG+ diag port, straight off the ignitor, and on the ECU with a spare tach and it does this at every point. Has anyone ever experienced this?
