Front Wheel Hub
SilverSupraT
7M '78 Toyota Pickup
Oct 3, 2005
556
Eastern WA
www.geocities.com
Does anyone know the best way to remove it?
Book says take it to a shop blah blah... I work in a machine shop so I should have the tools or be able to make any jig that I would need. I'm just looking for a bit of guidance before I have at it.
I have a car with ABS as well if that makes any difference.
Thanks in advance!
SilverSupraT
Oct 3, 2005
556
Eastern WA
www.geocities.com
IJ.;981807 said:
Undo the nut behind the cap and press the stub out then pull the circlips and press the bearing out.
It's just a cap on the back side?! Granted I spent like a minute trying to figure out how it came off but when the repair manual said take it in I thought I should ask here before I break something.
Thanks! I'll give it a better go-at-it in the morning.
SilverSupraT
Oct 3, 2005
556
Eastern WA
www.geocities.com
...hmmm... So just to double check. On the rear of the car there is the dust cap, castellated nut with a cotter pin, then you pull the hub off to the outside of the car. On the front the dust cap is on the INSIDE along with a similar nut/cotter pin setup?
