I still have a massive oil leak on my 7MGTE. I changed the oil cooler lines since they were wet, but it's still happening.  I get oil all over the st.rack, the crossmember, and then it sprays around making wet spots all over. Damn mess.
Anyhow, what's a typical signature if the cam or front-main is leaking? The timing cover it dirty, but it does not seem to seep oil. If it's the front seals, would the oil only leak out that small drain-hole under the crank pully?
I guess I need to reinspect the oil return hose near the FPR too.
Under the turbo is dry, that's good. Not sure about the turbo return at the block however. As noted, the oil is just coated everywhere.
This sucks.
This sucks.
