I have a oil leak from the front part of the motor.
I removed the timing cover to see if the leak I have is a cam seal.
If the cam seal is leaking, will it leak in front of or behind the inner metal cover bolted behind the timing cover?
Looks like there is some oil behind the pass side cam wheel but the oil is not on the outer side of the inner metal cover.
The oil is around the water pump area.
