went to finish my install today and nothing. So i opened up the actual casing and the plug connector inside the S-AFC was actually half off so of course i was happy and delighted that i found the problem. But when i put it all back together and turned the key to "ON" i still got nothing.
I'm pretty sure i have the wiring correct. It isn't hard when you have the pinouts and schematics on paper. I have the grounds connected correctly with the brown wire closer to the ECU and the black wire a little more then 1 cm away from the brown wire, but on the same harness wire.
Ideas?
Ideas?
