So I have a 92 7mgte I just recently purchased the car, its been freshly built <1000 miles on build. The previous owner had many BHG issues so this last time he had the block and head machined, pistons replaced and cylinders over bored crank balanced and micro polished and many other little miscellaneous things done to it. Car is completely stock at the moment only thing done to it was a lexus afm because he no longer had the original afm. I've put about 300 miles on the car since I've gotten it, i put in original arm as to be safe and not run lean. Anyways after running the car for awhile i decided to push a little and I'm hitting fuel cut, all hoses have been checked and i have even performed a boost leak test and everything has checked out fine, i also have developed a fluctuating idle, nothing too serious but it wasn't there before. and lastly the last tie i pulled off the afm to perform a boost leak test i found an excess amount of oil on the afm and in the accordion pipe, could this be a cause of some of the problems? also car has no cel, except after hitting fuel cut which goes away after a free seconds. Did i screw something up??
