For those of you running Aristo Ecu on 1jz
RockPaperSwoRD
I have aCustom User Title
Jul 26, 2008
392
SanAntonio
Im currently in the process of getting this to run right.
engine is
stock 1jz(twins),
1jz harness.
New wires running to injectors(for sequential injection)
aristo auto ecu
AEM UEGO wideband
Map ECU2 running map eliminate mode <----this is my map sensor signal
r154
The engine turns on( fuel pump is currently jumped in the diag port), but my wideband reads 10 afr!!
i test drove it and seems to drive decently(although very rich) and turns off when out of gear.
when i went wot, it builds almost no boost and the wideband reads "--" so it could be extremely rich or extremely lean.
Before i put the aristo ecu in the car was running perfect on a 1jz ecu and tuned on stock twins 18psi on the mapecu2.
So is there something wrong with my ecu? are you guys running stock injectors with the aristo ecu?
