All questions have been searched but theres either not enough info or I'm just confused....Any help would be appreciated
1. I have usdm 550 injectors and I know I need the 7m resistor pack.... Where and what does the resistor pack look like?
2. With the 550's the 1jz injector clips dont fit so I either need 89+ clips or 2jz clips correct.?
3. I plan on going single turbo when I drop this in, the map sensor is only good for/ up to 18psi correct.?
4. If question 3 is correct, do I need a map ecu 2 or mines ecu to go higher boost than 18psi or can I use my emanage, USDM 550's, E-01, WB, MSD dis-4, FPR combo that I have already with the 2jz stock map sensor in? I'm just confused with this one...
5. I dont have a 1jz power steering resivior... Do I need a 1jz resivior or can I use a 2jz or 7m one?
Thats it for now....... I'll have more questions in the future about the swap but I'm just trying to get all of the peices to the puzzle together. Thanks for your help
