flywheel question
quicksilver
56
owensville mo
Hey its been along time since I posted on here, but I have a question. Is there any other flywheels that will bolt up to a 7M that has a different dowle pin pattern on it. I got a used fly wheel reserficed and put it on, put the trany on and now I cant seem to get the pp to line up.
shaeff
Kurt is FTMFW x2!!!!
9
Around
if you have a turbo, and the flywheel you got is an N/A flywheel, that might do it. an n/a flywheel will bolt up to a turbo motor, but i dont believe it'll line up with the PP.
-shaeff
souprat
fairfax VA
i made the same mistake last week putting my clutch in. shoulda test fit the fw and pp. but i just kept turning the pp and seeing if it would match up. there is only one way they will fit together. so i put in one bolt in then turned the fw to see if the next bolt hole would match up, if it didnt then i would take the bolt out and try a different hole. eventually i got it.
