FlyW dowl pins
If they're bent or otherwise damaged, they need to be replaced. When you have it machined they should have the tool to pull them (special slide hammer)
Jeff Lange
Administrator
4,918
4
Calgary, Canada
jefflange.ca
Dowel pin removal slide hammer to remove them. If they're not damaged, they need not be replaced. If there is any question, or you just feel like being on the safe side, replace them anyways.
Jeff
