FL 2.0L battery fuse - how 2 replace?
=SAI=
26
Szczecin
Hello.
Let me begin with some facts:
Fuse box from under the hood AKA- J/B no.2 is connected with positive battery terminal via white thick wire. Although this wire is not connected directly to battery. The whole circuit is protected from any problems that can occur on the line between battery terminal and fuse box, by a small fusible link with code name FL 2.0L
You can see it, on the top of this diagram:
It's a short blue wire joined with the white one from fuse box with heat shrink.
In my case, it's like 1/2" that left from this fusible link wire
so I need to replace it with some wire with common resistance or extend it somehow.
Do you know anything that might be helpful?
Thanks in advance ;)
