I finally got my rebuild up and running with all the minor issues adderssed! I can write a book on what f ups and headaches too look out for so yyou can build in confidence and have no rod knock like i have done 4 times successfully.
JE pistons .040 over
stock rods all resized which is key for rod bearings
hks 1.2mm HG
arp rod bolts
arp head studs
kings rod and nain bearings
relocated oil filter and cooler
shimmed oil pump
emanage
vpc
720cc injectors
4 puck clutch sprung
custom FFI
Q45 throttlebody
7m tps mounted 80.00
custom 3" ic intake
12x24x4 ic
2.5 ic to turbo all ic pipe in bling bling Aluminum
gt4088 .81 a/r turbo
3" vaband flanged custom down pipe
egt auto meter
afr autometer wide band comeing is zetronix data logged and monitored by e01 and emanage
E01 boost controller
Aeromotive afpr
walbro pump
billstein struts and supension teqnique 1.5 drop springs
dual contour electric fans blowing like a prostitute that just got paid
future mods in like one week
2 walbro tank set up and plumbed for 2 walbros next chance I get going in
dual fed rail end to end with return in middle
standalone? undecided as yet
http://www.cardomain.com/ride/571789/14
new current pics to come
hks 1.2mm HG
arp rod bolts
arp head studs
shimmed oil pump
emanage
vpc
720cc injectors
custom FFI
Q45 throttlebody
custom 3" ic intake
12x24x4 ic
egt auto meter
Aeromotive afpr
walbro pump
