FFIM question.
mk3
70
Australia
friend suggested i make my own FFIM by using a 1j FFIM and cut/welded on the 7m bottom ?
any one done this ?
any one think it would work ?
let me know your thoughts thanks :)
7Mboost
7M Powered
Aug 15, 2006
2,201
Gainesville, FL
Its been done, you'll have to do a search to find the one, but I think you need to make an adapter plate because the runners don't line up exactly.
2_TonedMKIII
Rarety
Jul 28, 2006
64
Orlando, Fl
It's been done. I made mine using the Greddy MKIV surge tank. In my opinion alot easier than stock 7m to 1j ffim, however also in my opinion I would just buy one. At the moment I can't remember who makes them now.
sethron71
Authorized Vendor
Jul 19, 2005
871
Las Vegas, NV
www.SethIngham.com
Personally after building 10's of custom ones and as well doing modification on stock manifolds it is easier to just go fully custom. You start dealing with not being able to port the inside, port matching, and dirty cast metal.
Just my 2cents!
Seth
Facime
Leather work expert
Jun 1, 2006
2,716
Corvallis OR
honestabe;1119666 said:
Ron R.(JT2MA71) is currently making FFIM's, but he has quite the waiting list.
I heard this rumor that a guy in VA makes em too...Seth something or other ;)
The advantage I can see to modding a 1J/2J intake is that it would look factory made. If you are going for that kind of look it might be worth it. If you simply were looking for a cheap FFIM, go custom.
Facime
Leather work expert
Jun 1, 2006
2,716
Corvallis OR
honestabe;1119850 said:
Sethron? Something like that. I remember reading about that too, but I couldn't find anything on it.
Psst...he posted right above you up a couple posts. ;)
CRE
7M-GE + MAFT Pro + T = :D
Oct 24, 2005
3,485
Denver, CO
[strike]No... that's not it... but it's something like that. I think it actually starts with a "G"... or was it a "W"? hmmm, I'll post back if I think on it.[/strike]
I REMEMBER!!!! It rhymes with Exxon! (or was it Chevron?)
zachm611
Beauty In Disguise
Apr 15, 2006
543
new mexico
Seth recently made one for me it turned out awesome! i'll post pics after i take some, it polished up nicely too :] after i go standalone id like another one with out the ISC/CSI flanges so it'll look clean. hope you'll still be making manifolds in a couple years seth!
MarkIII4Me
Project OVERKILL!!!
Apr 10, 2005
1,249
Charleston, SC
I'd have to agree with the above posters and go fully custom. For the money I have in my IJ to 7M FFIM, I could have easily gone custom for less. They do look pretty good mounted, but the inside is not smooth at all. Not to mention, getting around the TPS issue is a RPITA!!!
8,873
The majority of owners don't need it, and lose a broad powerband for higher peak numbers from the shorter runners and larger plenum.
sethron71
Authorized Vendor
Jul 19, 2005
871
Las Vegas, NV
www.SethIngham.com
Not true at all with a long runner custom manifold. You only lose about 2" of runner in return for a bit larger plenum. But any low end lost from the shorter runners is more then gained back in the IC piping which is half the length of stock! As for short runner manifolds I completely agree as mine have almost double the plenum volume! I recommend them for applications of 600rwhp+ and everyone else I recommend the long runner manifolds for.
HTH,
Seth
8,873
All true at all. You describe just what I said.
uh, i will happily lose a lil on the powerband to get rid of an assload of piping and a lot less throttle response. If its not needed why did the 2j and 1j get them?
Actually, with most the pictures I see, you lose a large in the powerband for a small gain. And don't make things up like a lot less throttle response.
