few things going on with the motor now.
1)wont hold fuel pressure via a gauge on the FPR. walbro 255 i can hear it come on only durring cranking not with key "on". i get pressure while cranking but will drop off to 0 after cranking. lines are SS from FPR to rail, rail to FPR and SS down to the return. stock hardlines from there back to tank and from pump to firewall its stock hardline then SS to the FPR.
2) car turn "on" but when i go to crank it wont (like the NSS is not right) but the NSS is wired correctly cause i didnt change it from the previous set up. i can jump the starter with a 12v wire and get the car to crank.
CPS timing is off so i need to pull that again.
1 week till the NE meet........................
