So I found A fan clutch and blade from a lexus ls400 at the junkyard.
Im gathering parts for a 1jz swap. The block already has the 2jz waterpump installed, The ls400 clutch bolt holes matches perfectly with the 2jz waterpump, however i dont have the pulley.
Can anyone confirm if the ls400 fanclutch AND Blade is the same used in the 2jz?
