I have a 1991 Supra Turbo and I am having ignition problems. I tested the coil-packs in an unsafe and now to be determined, invalid way. I imagine you can assume the attempt I made but just in case you can't, I pull the sparkplug wires off the coilpacks 1 by 1 and had someone attempt to start the car. Coilpack 1 had no spark. I replaced the coil pack (have not tested this coil pack which could be the problem, but 2 bad seems kinda odd) and nothing happened. What happens when I attempt to start the car is...
1. I turn the key (sometimes I have to hold the key turned, nothing happens for a while)
2. The car cranks and the car attempts to start, it sputters and will continue to sputter until I stop or rarely the car will stop itself.
One time after replacing the coilpack I felt like it was going to start. You can sorta tell when a car is about there, and it felt like it was...
The previous owner installed a 7MGTE into the car (came stock with the GTE) and the car was running he says. I traced the coilpack wires back to one 4 pin connector near the right side of the head. One wire seems to be cut (still connected, but the rubber wrap around it is cut to expose the wire). My mechanic is going to take a look at the problem, but I am trying to give him some helpful hints as to what to look for and what may be causing the problem. I have looked into replacing the ignition box as that might be the problem but I don't want to make any moves until we sorta have an idea of the problem. I reset the ECU after I installed the coilpack and still nothing.
EDIT: Error code 14 is now gone... I am throwing no codes
