Search "electric fans," and pay attention to posts on that topic from SupraCentral. Search "fan clutch," and look for posts by Jetjock.
The operating temperature for this engine is basically the same as any other fuel injected engine. If you don't know what it is, you might not want to "upgrade"(or fuck up) one of the most critical parts of the cooling system. Try doing maintenance (i.e.: hoses, thermostat, cooling system flush, rebuild the fan clutch) first, and do some research on how the cooling systems works, and why. You'd be better off getting a better radiator, and leaving the stock fan in place.
Here's a good place to start:
http://cygnusx1.net/Supra/Library/TSRM/MK3/manual.aspx?Section=CO&P=2 Study that, and the next page or two as well.
Edit: lol, nm. Kc made it easy for you...
