A couple of questions on my swap that is currently going on. The recipient is a 1991 7mge auto car the donor drivetrain is from a 1988 turbo 5spd.
The first question i have is that I noticed that the shifter opening is quite small. Will I need to modify the trans tunnel(ie: sawzall it) and do i need to get the 1991 shifter boot assembly(the rubber part, not the leather) as the holes do not line up to the 1988 boot?
Second question is a wiring question pertaining to the engine harness, more specifically the plugins behind the glove compartment. The turbo motor has 4 plugs on its wiring harness, yet the 1991 only has three plugs behind the glove box and they are different styles than the turbo harness. Do I need to make a hybrid harness using the 1991 connectors or what? Thanks in advance.
