:1zhelp: So my engine stalls at lights or stops, this only happens when the engine is cold (most of the time). For example, when i start the car for the first time in the morning. It starts fine, I go down the block shift into 2nd (i have a 5-speed) then push the clutch and put the car into neutral to prepare to stop. When I do stop the call will stall. The only way form getting the car not to stall is to hold the gas down as to get a steady rpm, witch is kinda hard when braking.
any thoughts?
p.s. my car now has 125k on it witch motor oil should i consider using?
any thoughts?
