on the diagram I have of the way to hook up the ignition harness, with the 1kohm resistor and the transistor, everything eems to be a bit jumbled.
I've got the ground going to the collector of the transistor,
the IGf going to the emitter, and capped off on the ignitor side
What does the IGt wire go to? I've got the base of the transistor free, also the 'IN' of the emanage to go to. and the RPM to splice in (I can figure tha out)
answer me that and i'll make a much more clear diagram
