First off, here's a list of things not working at the moment:
Fog lights
Tach
Passenger window switch (drivers still works for the passenger side)
tail light failure light is on
cig lighter wasnt working, but it was unplugged, didn't check to see if that fixed it but am assuming it did. there was also a black 2 wire harness that i couldn't figure out where it went, it was beside the emergency flasher switch.
so far i took the fog light switch apart. while i had it apart i plugged it back in and made the connection manually, the switch light wasn't turning on but i could hear the relay clicking. lights didn't turn on.
any ideas on these problems, could some/all be linked?
btw i bought the car as a shell and swapped in a 1jz.
Fog lights
Tach
