I have two problems that may be related. First, something was running the battery down while the car was sitting. The battery would be stone-dead
within three days. While working on this problem the car decided it would not start. Would turn over fine, but I put the spark tester showed no spark.
I have 12 volts at the coil primary and 12 volts going to the igniter. I tried a spare igniter, but that didn't help. Last year I replaced the four pin connector
going to the cam position sensor when I had this same problem. Any ideas?
I recently put the original radio/cassett player back in the car. Do these have a memory that uses a lot of battery? Run the battery down?
The car is a 1987 7M-GTE with 115k miles.
Thanks much for any help!
